connecting matlab to c language dll
hello
i'm trying to use clllib function in matlab i put .dll file and .h file in the same directory as the .m MATLAB file being developed and after that i try to use loadlibrary function but it have some warnings:
>> loadlibrary('t1.dll', 'T1Header.h')
Warning: Message from C preprocessor:
lcc preprocessor warning: C:\Users\MAHNAZ\Documents\MATLAB\T1Header.h:21 No newline at end of
file
> In loadlibrary at 351
Warning: The function 'Add' was not found in the library
> In loadlibrary at 435
Warning: The function 'Function' was not found in the library
when I want to use the calllib function like this: calllib('t1', 'Add', 2,3) matlab gives me an error:
??? Error using ==> calllib
Method was not found.
my header file is:
CODE --> C
#ifndef _T1_HEADER_H_
#define _T1_HEADER_H_
 extern "C"
 int Add( int a, int b );
 void Function( void );
#endif
my source file is:
CODE --> C
#include <stdio.h>
#include "T1Header.h"
 extern "C"
      return( a + b );
	   printf("DLL Called.\n");
I use visual c++ 2010 and Matlab 7.6.0(R2008a)
Any suggestions on what is wrong, what I could do to fix this error, or what else I could try to call this .dll from within MATLAB?
RE: connecting matlab to c language dll
To get rid of warnings, add a new blank line at the end of file.
If you're using the MS compiler, use Visual studio to create your DLL. It adds quite a few extra bits like exports, which are missing from your code
