Does AutoCad have dynamic rotate?
I am learning AutoCad v14. I have previous experience
in Catia only.
How can you rotate a model dynamically?
All I can find is that annoying tripod and the dview
function which doesn't serve my purpose.
You can pan,zoom dynamically...but where is rotate?
Thank you
in Catia only.
Thank you
RE: Does AutoCad have dynamic rotate?
When dragging or rotating, for that instance, dragmode is the variable for watching the objects look as they will when you end up the command. Set dragmode to auto.
Despite of this, if you're dragging over an image, the dragging will not become evident, until you're done.
Hope this helps,
Roberttx.
Since I posted my question, I used the command 'Orbit' in the AutoDesk product called Volo View Express. That is exactly what I want, but I can't find it in AutoCad R14.
Does it exist as a addon?
I also used '3D Dynamic View' to rotate part but there is
too many steps involved.
For example, in other Cad programs, you hold down 2nd & 3rd
mouse buttons, and as you move mouse up/down or left/right,
the model moves accordingly on the screen. This is very
convenient since when one works in 3D, Pan/Zoom/Rotate is used a great deal.
Excessive accuaracy is a sign of poor breeding. -Socrates.
But... you have dview, which is a dinamic way to look at your 3d model. Final coordinates of the model is not rotated, but the view.
You also have vpoint, which is a more static way to look at your model using angles.
Hope this helps,
Roberttx.
The tripod works well also, once you get the hang of it, but orbit works so much better. That, however, would require an upgrade.
I could only use the command 3dorbit in 2000
There is a tricky solution in AutoCAD R14 and previous releases.
The DVIEW command, "CAmera" option rotates the model dynamically.
Farzad
Yup the 'camera' option is how you rotate 3D in ACAD 14. But I used to find it rather difficult to control and manage. It's was really disapointing when you want to get a nice angle.
But when ACAD 2000 came out, the orbit command was a breeze! A real advantage for 3D people like me.
I guess either upgrade or try try try!
Daniel Dorall
