Two bound materials in compression - formulia wanted
Like to find (on Internet ?) formulias for the effects of compression on two epoxied together materials of different "E" and cross sectional areas. Any ideas? Thanks.
RE: Two bound materials in compression - formulia wanted
Thread http://www.eng-tips.com/viewthread.cfm?qid=250463 has some info about compound sections, which I think is what you are interested in. The simplest methodology consists of factoring the width of various segments of a beam according to its modulus. A more sophisticated and generally applicable approach uses the area and modulus multiplied together for all materials. These matters are covered in mechanical engineering text books such as Gere and Timoshenko.
