Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I have answered some questions and have gotten answers for my questions. Anywhere you can do this on one page helps tremendously..."
Geography
blitz97 (Mechanical)
8 Aug 12 16:31
Hello all
one of our products maintains a water level of 1/2" when not in use. Looking at adding a slow type of drain hole(about 1/8" dia) in aluminum that will always be "peeing" while in use but will allow the remaining water to drain when not. Wondering if anyone has any knowledge of hole shape/size/dia data so this low head height water will drain without just covering over the hole due to surface tension of the water. Maybe the hole should be tapered? maybe a radius on the top edge? Trying to get a feel for any applications out there before testing....
1gibson (Mechanical)
8 Aug 12 17:28
Maybe an off the shelf small NPT "muffler" like used on a vacuum pump or air tools, would have the desired effect of wicking out stagnant water, but also reducing "active" leakage better than an open hole. Will only work if it drips, meaning you might need to tie a string to it.
Compositepro (Chemical)
8 Aug 12 18:14
Small holes tend to plug with debris easily. What is the problem with a larger hole?
8 Aug 12 18:55
a larger hole would cause loss of pressure in the chamber in question during use.
a micron filter we use upstream should negate this some but its still a concern..I agree.
Our options here are limited.
9 Aug 12 15:11
Sounds like you need a drain line with a float valve.
MiketheEngineer (Structural)
9 Aug 12 16:41
Sounds like a toilet to me??
13 Aug 12 9:26
Thanks everyone
I'll have to ponder the drain line with a float...
Am testing different shapes of small drain holes this week.
stgrme (Mechanical)
13 Aug 12 15:57
Try a plug-resistant orifice, such as those supplied by CU Services. Follow the link below:
http://www.cuservices.net/index2.html
13 Aug 12 17:35
I think MiketheEngineer may have been suggesting a P-trap, like you find under a sink. These are commonly used in condensate drain lines of A/C units. It allows water to drain freely but blocks any vapor flow as long as the pressure is greater than the liquid column height.
Close Box
Join Eng-Tips® Today!
Join Us             Close
