Pressure Reducing Valves
I am designing wet riser system with landing valve and 25-mm hose reel for a 4-story building. The building is a part of a campus with a fire ring main maintained at 10-bar (150-psi). The owner asked me to provide landing valve with PRV & should have PRV at hose reels. The system is to be designed based on British Standards.
Question: In my opinion, the system does not require PRVs because the ring main pressure which is fitted with a fire pump is 150-psi
NFPA standard calls for PRV if the system pressure exceeds 175-psi. I don’t know British Standard.
Any reference to British Standard for maximum pressure will be appreciated
Please help
Please help
RE: Pressure Reducing Valves
as in a fire department connection, that a fire truck would add pressure over 150 or 175??
or some other scenario????
