Default to no hidden lines in Section views only
Is there a way to default no hidden lines for section views only? I want hidden lines as the default for all other views. I could not find anything in the Customer Defaults or Preferences specifically for section views. This is for NX 7.5.
Thanks.
RE: Default to no hidden lines in Section views only
Preferences -> drafting -> general -> setting from seed part or from standard.
Can be a setting in your seed part, or depends on setting on your used drafting standard. There are structured settings controling it.
I don't see how this helps since I am trying to turn off the hidden lines by default in only the section cut views, not all views. Is there a way to set this specifically? Maybe I just don't see where to set specifics in the seed part?
No, I really don't think there is a way to do that.
