FAR 25.613 and A/B Basis Applicability
Hello everyone,
I'm a bit new with dealing with FAR 25.613 but I have a question, or a request, that many of you may be able to help with.
I work for an aircraft component supplier (mainly landing gear hydraulic controls, actuator). The airframer is attempting to flow down some requirements regarding applicability of FAR 25.613 and A/B basis materials to our components. My understanding is that FAR 25.613 relates mostly to critical structural components of the aircraft and therefore, would not be a firm requirement for the types of parts we make. The reason this poses a problem for us is that we're using 17-4 CRES at H1025 in our assemblies and only an S-basis property exists in MMPDS. The sampling and testing program for us would be prohibitively expensive.
Does any one have any insight on documentation that relates to the intent of FAR 25.613 and the regulations regarding A/B basis material? It seems to be generally vague with the exception of some white papers which speak about A basis for critical aircraft structure and B basis for redundant critical structure.
RE: FAR 25.613 and A/B Basis Applicability
Does an S-Basis material from MMPDS satisfy Section A of FAR 25.613
FAR 25.613
a.) Material strength properties must be based on enough tests of material meeting approved specifications to establish design values on a statistical basis.
> no, it does not. The FAA specifically removed the inclusion of S-basis values in 25.613 some years ago. S-basis values do not have a statistical basis.
> you need to prove that either a) your component is not flight safety critical (hence not needing a stress analysis and allowables), or b) you conduct sufficient system level tests at high enough loads to certify be test.
In MMPDS,
Section 1.4.1.2 "Statistically Calculated Values"-
Statistically calculated values are S (since 1975), T99 and T90. S, the minimum properties guaranteed in the material specification, are calculated using the same requirements and procedure as AMS and is explained in Chapter 9.
The way that the FAR is written, it appears that Section A is to ensure that materials with design properties that are established on a statistical basis are being used. Section B then goes on to speak about the requirement for A or B basis materials for critical structure. If A or B basis were required for all components, why have Section A at all?
Also,
> you need to prove that either a) your component is not flight safety critical (hence not needing a stress analysis and allowables), or b) you conduct sufficient system level tests at high enough loads to certify be test.<
Where is this written? Or is this more of a tribal knowledge thing?
All of our components will be proof, burst, impulse and endurance tested to FAR 25.1435 for qualification. For serial production, each unit will then be functionally tested and proof pressure tested before shipment. We do not have any flight critical components.
Thank you. I think I have a good understanding now...or at least I think I do.
"S-basis" allowables exist for historical reasons in MMPDS. And to (somewhat) understand why the FARs are written as they are, you need to dig up and read all of the previous versions back to the 1950's.
It has been pointed out that in absence of A/B allowable instead of developing of expensive statistical allowable we can use e.g. s-basis values and validate the analysis by a test. I have seen this type of approach e.g for metallic brackets, where analysis was done based on s-basis or other material data sheets. Finally 3-5 parts have been tested to include some statistics of material properties variation. Would be a single test assuming high MS not enough to satisfy FAA regulations and show that the part can carry more load than enough? From where can come the statistical requirement on a part level? FAR 25.613 implies the statistic for material properties only.
A fairly good discussion of metallic materials S, A and B basis properties is given in AC25.613-1 MATERIAL STRENGTH PROPERTIES AND MATERIAL DESIGN VALUES
http://www.airweb.faa.gov/Regulatory_and_Guidance_...
Similar discussion for composites is available in various ACs.
Many/most FAA Advisory Circulars are available for free download at: http://www.airweb.faa.gov/Regulatory_and_Guidance_...
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
S(a)cceptable = S / SF
S = S basis mechanical property
SF = safety factor ~= +15% = 1.15 [or whatever their rational SF is)
in this example... S(a) ~= S * 0.87
NOTE: I have seen this SF applied to materials and fasteners, not [A or B basis] listed in corporate or MIL/MMPDS design documents
Mechanical properties often took a significant "hit"... but could be used none-the-less under this rationale.
Regards, Wil Taylor
Trust - But Verify!
http://projects.battelle.org/mmpds/Aging%20Aircraf...
