Estimated cost of AC equipment for large scale PV design
I am involved with a large Utility Scale PV system design which will include connecting an 100MW PV farm into the utility system.
I currently need to come up with an "Ballpark" equipment cost estimate for the equipment that will be required on the AC side of the inverter to connects the system onto the utility grid. Without looking too much into the potential AC design I was wondering if there was an estimated $/MW cost estimate that could be used to estiamte the cost of the AC equipment on a large scale PV system. This cost estimate would inlude all hardware necessary for construction of the system.
Has anyone seen a cost estimate figure or have experience with this?
Thanks for the help.
RE: Estimated cost of AC equipment for large scale PV design
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
they will tell you what you must use.
sounds as though you are a bit out of your depth here my friend.
really a 100MW system?
