family parts in the reuse library
Hello, I'm trying to create a library of metric i-beams to be used in the reuse library. I have the constraint sketch and created a family table and have applied all the sizes we commonly use. I have two questions. How do I add the length or extrude dimension to the input when the item is selected? When I add this to the family spreadsheet it doesn't allow we to edit the length on input. From searching the forums sounds like I need dash numbers but can't find an explanation on this.
Also is there a box to check to allow the reuse part added to be edited on its own. For example the one end of this beam needs a weld prep/miter cut applied but I don't want to effect the library parts or any other assemblies I've used the beam in.
NX 6.0.5.3 in Windows 7
Mechanical designer
RE: family parts in the reuse library
Best regards,
Michaël.
NX7.5.4.4 + TC Unified 8.3
Win 7 64 bit (Intel(R) Xeon(R) CPU X5650 @2.67GHz)
24.0 GB
NVIDIA Quadro 4000 + NVIDIA Tesla C2050
Mechanical designer
Mechanical designer
Mechanical designer
Mechanical designer
