Query on Pipe Supports
Good Day everyone!
Its my first time to post here, im hoping i would receive replies on my query and future queries as well.
Im a piping design engineer with no site/field experience thats why my knowledge is limited. Ill start my question with regards to proper selection of pipe support involving weld shoe/clamp shoe and U-bolt.
My question is what are the categories on proper selection?
Basically i know that weld shoes are used to support insulated pipelines of course provided that the pipe material allows welding. But with regards to cutting of insulation on point of support, clamp and U-bolt can be used right? But the use of clamp depends on the piping movement, clamp shoe cannot be anchored. U-bolt on the other hand has limited application due to temperature.
Say i have 1.5inch steam line with design temp of 400deg. C, project specs says that cutting of insulation on point of support for small bore lines is allowed. The piping is just resting but pipe span would require guide.
My design would be to use weld shoe and hold down guide on point of support for guide span. But the thing is for a small bore like that, im thinking if it is economical to use weld shoe.
Please do help me guys! some inputs and thourough explanation on proper support selection would really help!
Thanks!
RE: Query on Pipe Supports
endolet (Mechanical)
Webinar Series
Overview of How Piping Design & Analysis Influences Pipe Support Selection & Design
Over the next few weeks, our technical experts will take you through a series of presentations on piping, design considerations, effects on overall configuration, preliminary piping design, initial layout, the total system, introduction to pipe stress analysis, detailed piping design, and how all of this influences pipe support design
http://www.pipingtech.com/news/webinars/webinar_se...
Look at similar supports on similar projects for similar clients and copy those designs.
Until you have grey hair or no hair, the burden of proof you must satisfy is so great that owners and engineers will both prefer to "waste" tens of thousands of dollars on proven existing solutions then use an innovative but unproven idea. Even if that support is used in similar situations but in a different industry, it will not be welcomed in your industry.
Spring supports were to be avoided at all costs when I worked in one industry, but every other support was a hanger in the other.
Hangers were the de facto support in one and avoided in favor of shoes on the other.
No amount of logic, cost savings, time savings, etc etc, was going to change the minds of the owners in those plants.
- Steve Perry
http://www.linkedin.com/in/stevenhperry
This post is designed to provide accurate and authoritative information in regard to the subject matter covered. It is offered with the understanding that the author is not engaged in rendering engineering or other professional service. If you need help, get help, and PAY FOR IT.
