Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I think the site is just incredible....I am learning more here than anywhere else before and am looking forward to being able to help someone .... this is my idea of what the Internet is supposed to do..."
Geography
Aodwan (Industrial)
8 Aug 12 3:20
I don't know this is the right forum to ask this question, if not kindly advice me the correct one.
We have designed the channel cover flange with thickness 88.0 mm and the recommended deflectipn per TEMA 9.21 is 1.06 mm and coming deflectin per given formulae is 1.22 mm, now flange is already forged.
TEMA has suggested the reduction of deflection by using strong back, is there any section in ASME to support this, or any suggestions.
fegenbush (Mechanical)
8 Aug 12 9:21
If the thickness of the flat cover complies with the code of construction (ASME Section VIII Division 1 assumed), you may make modifications (addition of a strongback) per U-2(g). If your code of construction is other than ASME, let us know.
rhg (Mechanical)
8 Aug 12 14:37
Try reducing "G" diam. or bolt circle, or reducing deep of groove for pass partition.
rhg
Aodwan (Industrial)
10 Aug 12 11:43
Thanks for your advice, the heat exchanger manufactured under ASME codes.
Close Box
Join Eng-Tips® Today!
Join Us             Close
