Catch Basins in Gravel Parking Lots
Does anyone have any experience using catch basins in a gravel parking lot? I have always tried to avoid them due to obvious reason. I think I have seen them used before with a concrete apron around them to avoid dirt and gravel getting in them.
RE: Catch Basins in Gravel Parking Lots
Another component to watch out for is erosion over time. In a recent project I was involved with, I purposely set a localized depression where the inlet is so that water continues to be collected even as the edges erode over time. Even if a concrete apron is used, I would also consider this.
Recommend to the owner that they install (something like) gravel bags around the inlet whenever they re-surface the parking lot.
Will there be any snow removal? Depending on their snow operations, this has the potential to greatly increase the rate of gravel transport into the inlet.
