Loads on Flexible Diaphragms
I have a question regarding seismic base shear and the earthquake load force combination described in IBC load combos section 1605. The base shear according to ASCE is V=CsW. That is the load that is applied to both the transverse and longitudinal direction. How does the Earthquake load come into effect? The static lateral force procedure refers to the seismic base shear, not the earthquake loading combo? Please help. Thank You
RE: Loads on Flexible Diaphragms
