5160 Spring steel vs. grease question
Would some really good metallurgist go up to thread108-326877: Can lubricant actually damage spring steel?
and see if there is a metallurgical reason for what the OP has posted regarding Eaton's claim that grease degrades 5160 spring steel? Even if you aren't a good metallurgist, give it a try anyway.
rmw
RE: 5160 Spring steel vs. grease question
Maui replied to the thread in question, as did I. We are both metallurgists.
