Can Catia Search Sub Folders For Part Files
I am still unclear about
1) Can Catia search sub folders of the folder "folder of the Link" Setting, and if so how.
2) How do I know where teh relative path starts. Is there an ini file or something that can be set.
I want to copy files off the server and work on them locally for speed, and then put them back on the server in a different relative path. I use sub folders in my relative path to organize parts.
Further, Someone else may want to copy the files locally, and then edit them. They will lose all the links if there is not a way to tell catia to look in sub folders.
Help is very much appreciated.
RE: Can Catia Search Sub Folders For Part Files
I am Not Sure Which Document I should be looking For.
Is it the user guide, ?. Do you have a link to it.
Dana
Inside Catia press F1, if your help pages are installed this will start in a browser.
Full Text Search for "document search path"
Look for Applications - Document
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
Hi JSPROSENG,
Here is a link (you will probably have to have to edit it's prefix to work)
file:///C:/Program%20Files/Dassault%20Systemes/B21doc/English/online/bascugen_C2/bascudocument0000.htm#hj-DocumentEnvironment
Hope this helps
P.S.: B21 is CATIA v5 r21, B20 is r20 and so on...
CATIA V5R21 – mold tool design engineer
