NACE MR 0175 Material Compliance
I want to know if the following materials are NACE MR 0175 compliant,
These are used to make fittings, equipment or accessories that are used for hot tapping. All of the products would be in contact with the H2S.
Thanks in advance.
Pipe Cutter body, back plate,and holder
1. SA 283 GR. D
2. A 572 Gr. 50
3. AISI 1018 / 1020
4. AISI 1018 / 1026
Pipe Sealing structural materials and bolt ( remain inside the pipe in the corrosive environment and resist different forces)
5. A 513
6. A 514 Gr. B or H
7. A 517 Gr. B or H
8. A / SA 574
9. AISI 4140 / 4142
10. AISI 4140 / 4130
11. 17-4 Ph. Stn. Stl H900
Bar, Plates, Coupling
13. A / SA 36
14. A / SA 537 Cl 1
15. A / SA 234
RTJ ring material
16. SS 304
17. SS 316
18. SS 347
19. SS 410
Thanks in advance.
1. SA 283 GR. D
2. A 572 Gr. 50
3. AISI 1018 / 1020
4. AISI 1018 / 1026
5. A 513
6. A 514 Gr. B or H
7. A 517 Gr. B or H
8. A / SA 574
9. AISI 4140 / 4142
13. A / SA 36
14. A / SA 537 Cl 1
15. A / SA 234
RTJ ring material
16. SS 304
17. SS 316
18. SS 347
19. SS 410
RE: NACE MR 0175 Material Compliance
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
For most of these materials it will depend on their specific thermo-mechanical condition. There are hardness limits for many materials.
Plymouth Tube
