IBC03 can reduce TYPE 1A to 1-hour rating?
Checking one project and see Architect drawing says" TYPE 1A with sprinkler, and specifies 1-Hour rating for column and beams and slabs. Is that right? Where is it in the code. I see 3 hours rating in table 601 and know there is reduction for high-rise to TYPE 1B, but still does not see 1-Hour.
Thank you.
RE: IBC03 can reduce TYPE 1A to 1-hour rating?
Might be a loco (sorry I meant local) amendment to the code by the AHJ.
Garth Dreger PE - AZ Phoenix area
As EOR's we should take the responsibility to design our structures to support the components we allow in our design per that industry standards.
