Open Throat Catch Basin Flow
I need to calculate the flow (cfs) that an open throat catch basin can handle. Currently i have calculated it using a rectangular weir formula but im not sure that is 100% correct. q=3.33(L-.2h)h^(3/2). Any advice would be appreciated. Thanks.
RE: Open Throat Catch Basin Flow
http://www.fhwa.dot.gov/engineering/hydraulics/lib...
THank you for the reference i will check it out.
Peter Smart
HydroCAD Software
www.hydrocad.net
A note pertaining to HEC22, FHWA has had alot of testing conduicted on various inlets and etc... especially the hydraulic losses through access holes.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East - http://www.campbellcivil.com
