How do I change the parameter label for an extrusion?
When I make a sketch I can change the parameter for a dimension easily from the default "P1" to something like "Diameter1". However after completing the sketch I can not find a way to change the parameter value for the dimension that shows the depth.
It is very nice to be able to have sensible label descriptions in equations and part family tables.
RE: How do I change the parameter label for an extrusion?
You can change the name of existing expressions in the expression editor (Tools -> Expression...).
www.nxjournaling.com
and then click on the expression, and listed below. after "name", just type over the p number with whatever name you want
