Tie contact error in a heat transfer analysis
Im trying to run a heat transfer analysis on a box in abaqus standard (steady state). A bulkhead is in the middle of the box tied to the two sides.
The BC's are two different temperatures on the different sides of the box.
The analysis stops with a message error: there is more than one temperature degree of freedom on node xxx
So can you help me please to run successfully this analysis?
Thank you
Thank you
