Inverse Get functions NODE(x,y,z)
Hello!
I would like to be able to retrieve the node number closest to a set of coordinates x,y,z and be able to retrieve the stress at each node that I select. I've read about inverse get functions and that NODE(x,y,z) should do the job, but I do not see such a function in the ANSYS documentation (using version 14.0). Is there some syntax I need to type in that I'm unaware of? An example would be great!
Thanks!
Thanks!
RE: Inverse Get functions NODE(x,y,z)
hope it will help
From what I can gather, these commands can only be used in a script? It doesn't seem to recognize it when I type it into the ANSYS command prompt.
coordinate_array(i,2)=NX(NodeNumberFromArray(i,1))+UX(NodeNumberFromArray(i,1))
