Verifying direction of rotation.
Hi guys.what is the best way to check if a motor is rotating in the right direction after installation or repairs on supply cable,without having to uncouple the motor.in particular situations where motor is driving equipment which is sensitive to direction change
RE: Verifying direction of rotation.
"Dear future generations: Please accept our apologies. We were rolling drunk on petroleum."
— Kilgore Trout (via Kurt Vonnegut)
For the best use of Eng-Tips, please click here -> FAQ731-376: Eng-Tips.com Forum Policies
How can that possibly be a sensible or simple solution in circumstances where, to quote the OP, "the motor is driving equipment which is sensitive to direction change "?
As many of my teachers used to say to me, "Read the question before answering it."
Can you expand a little on how to connect the rotation meter? Do you mean connect power to U1 / V1 / W1 and connect the meter to U2 / V2 / W2? I am trying to understand how it will determine correct or incorrect rotation of the shaft from such a connection.
Gunnar Englund
www.gke.org
