V16,90 degree Hevay diesel engine?
HI guys, i am new to here , have a question about heavy duty diesel engines , V12 or V16 90 degrees..Do any have seen succesful engines in this configuration? most of the engines are V12 45 or 60?
RE: V16,90 degree Hevay diesel engine?
... which is a good reason to make a V12 with a 60 degree angle; so it will more easily fit in the boat or truck or whatever. Even firing order is just a bonus.
ISTR that DDC/MTU/Tognum 2000 and 4000 series and similarly sized Caterpillar V engines all use a 90 degree V angle.
One reason for using the same V angle in a family of engines is that the automated machines used to bore the cylinders, deck the block, etc., are very expensive, but it's relatively simple to make one machining line handle different numbers of cylinder pairs, just by shutting off unused spindles, whereas changing the V angle requires a major structural change to the machine tools.
Mike Halloran
Pembroke Pines, FL, USA
Mike Halloran
