Default Part Attribute in NX 8
hi everyone, we are using NX 8 and teamcenter 8 , we want to make the part attributes that we need a standard for all users, we require for example the mass , status(Assy, make,..), oracle to be an attribute in the part, currently in each part we make we have to make this attributes from start,
so basically my question is how to make default attributes for each part we make that just needs to be filled out by our users, instead of making the attributes themselves from the start
another question, is there a way to have a default assembly navigator for all users with custom columns and organization of columns?
thanks alot, awaiting any help
RE: Default Part Attribute in NX 8
guys, plz I need a response to this proplem , thanks for any answer
Open your template file and add all the attributes that you want every new part to contain, save your template file.
If you don't have a template file, make one.
www.nxjournaling.com
how do I create a template for the part, and how do I use it to as my standard template for that part(I am talking here about the model template not the drafting or others)
thanks
