Active suspension and skyhook damping
I've become really interested in fully active suspension systems lately; it seems like a good corollary to learning about conventional passive suspension. Now, I don't have a background in control systems or anything like that, so my current understanding is almost nil. One concept I keep coming across is skyhook damping, where a damper (that is attached to the sprung mass?) is fixed at the other end to the 'sky', or inertial space. Could anyone tell me what that really means, or rather, how it functions? I have had a look at a few papers, but most talk about LQR's and different control strategies.
Thanks all.
Thanks all.
RE: Active suspension and skyhook damping
Cheers
Greg Locock
Cabbages, knickers, It hasn't got A BEAK!
Cheers
Greg Locock
You probably need to be old and Aussie to get it though.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
That's probably not what you meant.
Cheers
Greg Locock
Cheers
Greg Locock
Active Suspension: Any suspension that can move the two ends of the suspension independent of the relative velocity or displacement across it. The most obvious example is when we have a hydraulic actuator that is installed in place of the damper and can push against both sprung and unsprung masses independent of the relative velocity across them. Obviously a passive shock will not be able to do so.
Semiactive Suspension: A real-time adjustable suspension that generates a force that is a function of the relative velocity or displacement (or both) across the damper. Most dampers (or suspensions) in use currently fall in this category. Although we are able to change the damper setting, ultimately the force across the damper is governed by the relative motion of the sprung and unsprung masses. Unfortunately, the term "active" is often misused for this class of systems, mostly as a marketing gimmick. I have heard companies saying that the term "semiactive" sounds like something is not complete (or half-baked)! They play with the word "active"and call their system by that name because they can "actively" (read that as in real time) adjust the damping characteristics.
When I think of these systems (or any other), I like to boil them down to the first energy principles. If we can add energy to the system in a meaningful way (such as a having a hydraulic actuator) then it is an active system. All others are semiactive!
I'm actually not that fussed if the basic weight bearing is via normal springs, that does not compromise the 'active' nature
Cheers
Greg Locock
On skyhook control, this is just one criteria of a suspension control strategy - whereby (as noted above) we try to keep the car body still vertically and rotationally (pitch, roll) with respect to an imaginary "sky-hook". Sky hook must act in conjunction with other control criteria such as wheel vibration control (as Greg said, hard to do unless switching is very fast), end stop control (suspension travel is finite, and can hence conflict with skyhook) and other "overrides" such a braking, steering or other driver input.
To my mind, (and I'll admit some bias) the cleverest idea to get into the 3rd and 4th quadrants is the technology named as Vehicle Dynamics International magazine "Innovation of the Year" ACOCAR. http://viewer.zmags.com/publication/b41bd0bd#/b41b...
It seems the heart of the whole thing is the control laws that are used; I know the Lotus system was designed around suspension modal displacements, I'm sure there are other methods. If anyone has information regarding this that they can share, that would be really interesting.
Thanks again.
These 'semi-active' systems where damper or spring characteristics can be rapidly changed I prefer to call 'adaptive'. They are still passive elements that can only dissipate or store/release energy, not supply it; this is equivalent to a component producing force against (passive) or with (active) relative velocity. Active systems have certainly been created and used as mentioned above.
Groundhook is a similar control strategy to Skyhook except the unsprung mass is "connected" to the sky/ground rather than the sprung. This strategy seeks to minimize motion of the unsprung mass as it is disturbed. A hybrid combination of Skyhook and Groundhook can be implemented as well.
ttx - the basic function of a damper is to generate a force that opposes a motion. If the damper rod moves in, the force will always be pushing out, and when it moves out, the force will always be pushing in. ( neglecting gas pressure, compliances etc . ). If you look at this relationship in a force velocity plot, you will see that it can only describe points in two quadrants that are diagonally opposed. The other two quadrants would require a force in the same direction as the motion, which can only be achieved if we add energy.
Q1 has the shaft moving in, relative to the damper body, so the force is obviously 'pushing out'. I guess in order to preserve the [i]sequence[i] in gt6r2's post above, then yes, it holds true when applied to Q3, not Q2. Is this the logic behind Q2 and Q4 being the active, or energy input regions?
Obviously if you reverse the sign of just the force or just the velocity, you get negative power, ie the damper is adding power to the rest of the system.
Cheers
Greg Locock
So far as I know nobody has actually released a high bandwidth high power active system as a production car option. There have been various low bandwidth low power systems, which obviously did not set the world alight, and the more advanced Kinetic system lends itself to incremental steps in that direction, since the shocks are replaced by rams, and so the remote valve block could include a pump. Kinetic were at least considering their options when they were bought out.
Automatically controlled variable valving in shocks and variable stiffness sta bars aren't active, they are adjustable passive, which is usually classified as "semi active" or perhaps more sensibly "adaptive".
Incidentally a typical production cars's shock absorbers can absorb up to 1.5kW quite easily, so any so called active system that can't generate several horsepower is not even playing the main game.
Cheers
Greg Locock
This sounds like the Citroen D series hydro pneumatic system. The car would roll into a corner and have self levelled by about 1/2 way through it, way back in 1955.
Pat
for site rules
With respect to passive systems, the problem amounts to intelligent energy storage, something that combined hydraulic/pneumatic systems can do rather well. (my chapeau......)
http://dictionary.reference.com/browse/skyhook
Pat
for site rules
The power of a system based on this source of energy would be low, but I disagree that you can draw a line based on power and/or bandwidth to make a definition of active. An ideal could be a springless, damperless system similar to the systems in Formula 1 in the '90s, but something less than that could still be called active. If anything it ought to depend on some standard of system performance.
Additionally, in racing they also outlawed multiply articulated suspension systems and moveable pickup points, active or passive, that would vary wheel camber, chassis offset and other parameters. Perhaps variable control of any of these could be considered parts of active suspension. After all, it is not just the vertical motion of chassis and wheels that are defined by the "suspension".
If your suspension has variable geometry, why call it active? Why not call it, just for grins, a variable geometry suspension?
Cheers
Greg Locock
I think it is also important to make conventional definitions conceptual and not only descriptions of observed systems. That way we avoid arbitrary, "coloquial" defintions or definitions that are only contemporary or applicable only to a small subset or are subject to quick obsolescence. I'm not trying to define anything, but you have suggested a modification to the (presumed) definition to include a lower limit on power. I think this is particularly arbitrary what with the vast range of power needed for very broad ranges of vehicle weights, vehicle speed regimes and terrain roughness -from 35mph electric grocery getters to 200mph sports cars to pickups and heavy SUVs that may travel dirt roads. Also, power levels should be expected to drop, perhaps drastically, with improvements in technology. IMHO, we should not take what is a basic figure of merit -low power requirement- and use it as a disqualifier in the definition.
Also, I wanted to point out that "suspension" is normally taken to be the system that holds the wheel to the chassis and controls its motion. There are 6 degrees of freedom of movement, in some systems controlled each by a distinct suspension link. The Z-axis, normally controlled by spring and shock, is only one degree. "Active suspension", as you seem to define it, is only Z-axis control. But "active suspension" that controls ride AND handling would HAVE to include at least some of the other degrees of freedom. It sounds like systems that involve active control of the other suspension functions than the Z-axis are excluded in your definition.
As far as handling goes, tire forces are a direct function of the load they support. As such, handling would certainly be affected by the action of an active system.
My question, and it's probably a stupid one, is one of tires. Say a fully active system is produced for a road car. What would be the effect of making drastic changes to tire cornering stiffness, and/or vertical rate. I realize vertical tire rate is a function of inflation pressure, camber, etc., but I am curious about cornering stiffness. I suppose the system could always rely accelerometer info.....
Thanks for any thoughts, corrections.
Wil
One of the issues with active suspensions, and modern ESC systems, is that they can mask non-linear behaviour of the tire, so to some extent they can and do compensate for changes in cornering stiffness and so on.
For instance if one tire were going flat an ESC system would see the higher slip angles, and would brake the rear wheels (typically) to bring the vehicle yaw velocity back into line with the steering wheel angle.
Cheers
Greg Locock
So tires with stiffer construction, quicker response, harder ride and more grip than the designed for tires will tend to have those characteristics effectively neutralized and not affecting the output, probably except for the higher grip, -unless the computer looks for superior tire characteristics and exploits them.
This is not different than engine control which is a closed-loop system under normal operation, so that spark plug wear does not effect performance until they are far gone. And like the engine computer, the suspension computer will be reprogrammable. I can envision people selling handling chips for active suspensions to go with their wheel-tire packages.
