Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say that you guys RULE, a million thank you's to whoever created, and/or manages this site. KEEP UP THE GOOD WORK..."
Geography
Compression design allowables for sandwiched construction
irq (Aerospace)
5 Aug 12 17:35
The aim is to obtain the compression design allowables for a thin skin of prepreg on a honeycomb core of a sandwiched construction. Let's assume we have two options: 1 ply (0.01inch) or 4plies (0.04inch) on approx. 0.5inch panel. Because of the buckling it is not possible to conduct the uniaxial compression test on very thin ply (option 1). That is the reason why we use the specimen with multiple plies for uniaxial compression testing.
1) Do you have any estimate how the thickness of the specimen can impact the design allowables?
2) Can we use the values from uniaxial compression test to evaluate strength of 1 ply or 4 ply-based construction? I tend to say that 1 ply will require flexure test, but I am not sure about 4 plies. Do you have any experience about thickness limit of the skin from which we can safely use values from standard compression test?
3) Is it true that flexure test is used only to quality control and material selection and not to obtain design data quality?
I appreciate any help, link, or references regarding this topic.
SWComposites (Aerospace)
5 Aug 12 18:20
> compression strength typically decreases a bit with lower thickness (this is not due to bucking, which must be avoided, but due to reduced local lamina kink band stability)
> data for thicker specimen will probably be a bit higher, see above. Also, uni-directional strength is not really useful, unless you are using that layup in your actual structure.
> up to 4-6 plies you should use sandwich flexure data, particularly if the skins are cocured to the core
> laminate flexure tests are sometimes used for QC, but not typically for in-plane strength design data as the results can be unconservative. Sandwich flexure tests are typically not used for QC - too expensive.
SW
Close Box
Join Eng-Tips® Today!
Join Us             Close
