Orient View Tool options
I don't find in the Help the description of this setting.
Can someone tell me what does it ?
And in which case can be useful ?
Thank you...
Using NX 8 and TC9.1
RE: Orient View Tool options
OK, if you notice in the dialog you're being asked to select 2 vectors to define the orientation of the view. If the 'Associative Oreintation' is NOT toggled on when you select those vectors they will simply be used to define a local direction. However, if the option is toggled ON then if you select say an edge, face or datum to define a direction, the view orientation will be linked to those objects so if they move the view will move as well.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
