Temper bead procedure qualification
I am looking to qualify a temper bead welding procedure for 2.25 Cr 1 Mo material for a client.
After welding using a temper bead run placement, should I carry out PWHT as per code applicable to material or would that be defeating the purpose of trying to prove the temper bead process actual works in the first place?
Thanks.
Thanks.
RE: Temper bead procedure qualification
You should review the information below to fully understand the method of temper bead...
http://www.wtia.com.au/pdf/TGN-PE-02%20Temper%20Be...
typo - sorry
No, you would NOT perform PWHT
