Executing a Journal From a Macro, with User Dialog Entry
OK, in my last post I learned that I cannot execute an NXOpen DLL from Journal->Play.
I can, however, do it from Macro->Play, but I need to launch my Journal from my macro.
All is well, except when my Journal opens a file selection dialog box and my keyboard doesn't respond. It's like the macro locked out the keyboard until it is done. I tried recording the macro with "user entry on dialog boxes" turned on, but it didn't change what was recorded.
Any ideas how I can accomplish my task?
Jeff
RE: Executing a Journal From a Macro, with User Dialog Entry
Why are you attempting to launch the Journal from a Macro? What is it that you're trying to accomplish which you can't do by just launching the Journal directly?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
As part of the routine I am automating, I need to launch an NXOpen DLL (as one would from File->Execute->NXOpen). The VB.NET journal doesn't let me do that. The macro does. So I figured I can "wrap" my Journal in a macro and execute the DLL from the macro. The problem is my Journal calls a file dialog box and somehow the macro prevents keyboard activity while it is running.
Jeff
I thought I was onto something when I saw:
Preferences→User Interface→Display Dialogs in Playback option
in the documentation, but that doesn't seem to help either.
Jeff
Jeff,
I am also attempting to call a .dll code either within, or immediately following, my journal file (as a result of some error that won't let me change the color of curves I extracted in my journal).
I landed on both your last post (http://www.eng-tips.com/viewthread.cfm?qid=327153) and this one while trying to find a solution to the exact same problem...so please update this if you have found a solution. I also can not find a way to let me access my Journal's user interface while calling it with a macro, and I can't find out a way to call either the .dll or a macro which calls the .dll using journal.
Anyhow, I'd love to hear if you've gotten anywhere with this.
Peter
Peter,
Unfortunately, I'm still struggling with this and I have yet to find a solution.
Jeff
