Quartz to metal adhesive
I have an application where I need to glue a glass disc to the end of a steel shaft.
The assembly needs to withstand 120°C. Can anyone recommend a good adhesive for this purpose?
RE: Quartz to metal adhesive
Most adhesives would work okay. Epoxy or silicone would be good choices.
The alternative is to metallize the glass, then solder the disc to the steel.
