models going out of date and not updating as they should
I have been having trouble with models going out of date and not updating as they should.
To investigate, I created a simple part that starts off as an Extrude from curves, and then added some features to it: a Shell, a few more extrudes, some draft and some blend features. Then, using a couple of different methods, I edited the curves used to create the initial extrude and it seemed to update as it should. Then, I saved the file and closed all parts; when I re-open the part, and made those same edits on the original extrude, it now throws all or most of the features (the shell, other extrudes, taper, and blends) out of date, and the model will not update as it should. I have to go and re-associate all those features. I am using edit with rollback, and I used "make current feature" in my feature tree and tried both ways.
Others at my work are having the same issue. Any ideas?
RE: models going out of date and not updating as they should
www.nxjournaling.com
A file that was made to demonstrate the issue is attached.
Sorry, but you really need to start using NX the way it was meant to. The probelms will only continue if you don't.
