welded section torsion verification
I need to verify a welded section of a pipe loaded by torsion moment and connected (welded) to a plate.The welding is inside and outside the pipe. Can anybody suggest me a suitable way to do it? Is there any standard code that foresees it?
RE: welded section torsion verification
Anyway, if the sum of the throats of the welds is at least some 40% higher than the pipe thickness (the 40% is a factor of safety to account for the unpenetrated fillet welds), your weld shall have a resistance to torsion higher than the pipe itself, and you can limit your analysis to the pipe.
prex
http://www.xcalcs.com
Online tools for structural design
