Equivalent of Chinese Material Q235B
We are in process of ordering a guyed mast tower (meteorological tower) from China. The supplier has said that all structural material would be Q235B. Can body give me the equivalent in ASTM.
RE: Equivalent of Chinese Material Q235B
http://www.lhwfg.com/shownews.asp?id=4928
That page gives both (some of) the mechanical properties and the chemical composition of Q235B.
That's the best I can suggest, good luck.
“An optimist will tell you the glass is half-full; the pessimist, half-empty; and the engineer will tell you the glass is twice the size it needs to be”
http://www.rolexmetals.com/sdp/191736/4/cp-5142139...
I too want to know if there equivalent steels. But could you point me to equivalent steels in yield strength AND composition. I mostly interested in composition in regards to weldability (carbon and manganese content) and galvanizing (Silicon content).
Could you help me find in those aspects (of weldability, galvanizing capability and yield strength) equivalent according to EN10025?
Thanks in advance,
Oran
Here are the properties from Chinese code
- Q235A and Q235B have the same tensile and yield: 375/235 Mpa
- Both have the same allowable stress from ambient to 350C.
The differences of A and B when using as vessel plate:
Q235A: design pressure 1.0Mpa maximum, 16 mm thick maximum
Q235B: design pressure 1.6Mpa maximum, 20 mm thick maximum
Both shall not be used in toxic substances. Q235A shall not be used in liquefied petroleum gas.
So looks like B is better than A, though they have the same mechanical properties.
The Chinese project manager told us AQ235A is equivalent to : SA-283-C, SA-36, SA-307B.
So if you treat Q235B as the above, you shall be good to go, and I am pretty confident for it.
