Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
wayneter (Materials)
2 Aug 12 21:51
I have a copper flange and copper shaft furnace braze project with Boron Nickel filler metal to be performed in vacuum furnace. Problem: the alloy is C18150 - chromium zirconium copper which is not oxygen free. How to braze and avoid oxygen coming out during braze and joint not brazing. Is there a plating suggestion or flux that could be used to avoid the oxygen affecting the brazeability?
Helpful Member!  Metalhead97 (Materials)
2 Aug 12 22:13
wayneter,
How are you preping the surfaces prior to brazing? I would degrease followed by a activation/acid-dip to remove the surface oxide films. In the brazing furnace back-fill a N2/H2 (3-5% H2) reducing atmosphere several times. During the brazing process, the copper should remain bright.
MH
http://www.linkedin.com/pub/luke-autry/1b/510/566
Helpful Member!  EdStainless (Materials)
3 Aug 12 0:53
Your cycle will be fairly short, you only need to worry about near surface issues.
The idea of using a partial H backfill is a good way to go.
Have you thought about doing this in hydrogen instead of vacuum?
Plymouth Tube
6 Aug 12 19:45
Sorry Metalhead97 for the delay. I prepped with acetone. We were thinking of using argon high purity in vacuum. I believe i see what you are saying in reducing atmospheres removes the oxides. Could run in Hydrogen also. correct?
6 Aug 12 19:47
Sorry EdStainless, for the delay. I am considering Hydrogen also as it would allow reduction of oxides correct. Less likely to have oxides coming out in vacuum.
mfgenggear (Aerospace)
6 Aug 12 21:07
Wayneter
All the above are excellent suggestions.
"How are the edges being prepped. " metal head"
are the edges machined ? are the outer oxides being removed to obtain good bonding.
cleaning as suggested is also very important as mentioned before.
any acid dip ?
Mfgenggear
Close Box
Join Eng-Tips® Today!
Join Us             Close
