Reuse Library configuration
finally switched to NX 8.0.2.2.
I'm trying to configure the Reuse Library in Native mode.
I would like to set the 2D Section Library and the Reusable Object Library in a shared network folder, but NX show always the local setting.
Also I would like to set up the ReuseLibraryFasteners.krx in a shared folder.
Someone can help me ?
Thank you...
Using NX 8 and TC8.3
RE: Reuse Library configuration
Gateway-> Reuse...
I've set all via customer default, but NX still show her original library, located in NXPARTS.
Thank you...
