Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...I just wanted to say that you guys RULE, a million thank you's to whoever created, and/or manages this site. KEEP UP THE GOOD WORK..."
Geography
ChristopherChoa (Chemical)
2 Aug 12 10:30
I'm definitely new to HYSYS and other process simulation tools. I just have a question in HYSYS.. If I do want a sour water stripper with a caustic injection on it (this will entails having an equilibriun reaction between the NaOh and other components inside the stripper), should I still need to input reactions in the SIMULATION BASIS MANAGER or no need?
I will be using Sour Peng Robinson for my Fluid Package.
Any advise would be appreciated.
Thanks and Regards,
Christopher Kenneth Choa
MortenA (Petroleum)
7 Aug 12 4:09
HYSYS wont do reactions unless you tell it the stochimetrics and the equlibrium. I think you can do the reactions in the reactor if you use this.
10 Aug 12 22:44
Thanks MortenA for the reply. But I do want to clarify things. The reaction is a reversible reaction by double displacement only.
Should I still have a reactor even if I'm building a plant without reactor?
Many Thanks for the reply.
Helpful Member!  TD2K (Chemical)
10 Aug 12 22:54
I'd check with Hysys technical support for an EOS recommendation, I don't think sour PR will do what you need it to do in terms of the caustic injection, pH and the effect on the stripping of H2S and/or ammonia.
10 Aug 12 23:20
Thanks TD2K,
I think I will add several reactions in the package environment first.
Close Box
Join Eng-Tips® Today!
Join Us             Close
