NX Journal - Execute NXOpen DLL from within a VB.NET Journal
This might be a VB.NET question as opposed to an NX Journal specific question, but...
I am trying to call a standalone NXOpen DLL (that I would normally execute from File->Execute->NXOpen) from within an NX Journal. It is not supported by the journal record, so I am unsure how to do that.
For example (not real code):
CODE
Module NXJournal
Sub Main
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim lw As ListingWindow = theSession.ListingWindow
Dim displayPart As Part = theSession.Parts.Display
Execute C:\files\myNXOpen.dll
Jeff
RE: NX Journal - Execute NXOpen DLL from within a VB.NET Journal
I've been reading various other forums here and there, and I'm wondering if this can only be done if I compile my journal, as opposed to running it from Journal->Play (ALT-F8). Is that the case? Is there no journal scripting for File->Execute->NXOpen?
Jeff
Yup that is correct, you cannot call dlls other than nxopen and .net from within journals. If you need to do that you have to compile it.
"Other than NXOpen & .Net"?
The DLL I wish to execute is an NXOpen DLL. Does that make a difference?
Jeff
No the following libraries are supported in journaling
NXOpen.dll
NXOpen.Utilities.dll
NXOpenUI.dll
NXOpen.UF.dll
mscorlib.dll
System.dll
System.Windows.Forms.dll
System.Drawing.dll
if you need any other library compiling it is the only option, atleast as far as i know.
Ahh ok, so you only want to launch the other program? not access specific methods of it? then look into the execute method belonging to the session instance.
You might find the following GTAC example helpful
CODE --> .NET
'' This example demonstrates launching another VB .NET application's Main entrypoint.
'' The Launching application might look like this:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module NXJournal
    Sub Main()
        Dim s As Session = Session.GetSession()
        Dim ufs As UFSession = UFSession.GetUFSession()
        Dim lw As ListingWindow = s.ListingWindow
        lw.Open()
        Dim libname As String = "launch_it.dll"
        Dim fullpath As String = Nothing
        ufs.UF.FindFile("application", libname, fullpath)
        If fullpath Is Nothing Then
            lw.WriteLine("application\" & libname & " not found")
        Else
            Dim nada() As Object = {}  ' Main doesn't take any arguments
            lw.WriteLine("Launcher will now attempt to Execute " & fullpath)
            s.Execute(fullpath, "NXJournal", "Main", nada)
        End If
    End Sub
    Function GetUnloadOption(ByVal arg As String) As Integer
        Return CType(Session.LibraryUnloadOption.Immediately, Integer)
    End Function
End Module
CODE --> .NET
''Where the application being launched might look like this:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
    Sub Main()
        lw.Open()
        lw.WriteLine("  launch_it is running")
    End Sub
    End Function
End Module
Petulf,
Unfortunately, I don't know any details about the DLL. When I look at it with DLL explorer the only functions listed are:
ufusr
ufusr_ask_unload
?NXSigningResource@@YAXXZ
My understanding is that this means it is a C DLL, and not a VB.NET DLL so I can't use the Execute method.
Jeff
Are you certain? gtac has examples of executing java and c code from session.execute() so why dont you try;
s.Execute("path\library.dll", "library", "CallUfusr", nada)
I tried various methods ("callufusr", "ufusr", "call ufusr") and they all result in "object reference not set to instance of object" so I don't think I'm calling the right ones. I also assumed the class name is the same as the dll as in your example. As I said, I can only see the 3 functions in DLL explorer so I'm stuck. Maybe there is some other way I can probe the DLL for information to help?
Jeff
