Cap plate welds
Cap plate welds
Cap plate welds
If I have an HSS4x4x1/4 that needs a cap plate, what weld should I use and what cap plate thickness should I use?
I'm used to specifying a cap plate thickness that matches the HSS wall thickness.
I'm used to specifying a partial pen weld because I don't want to require inspection. But partial pen welds have min root thickness of 1/8" and have have an effective weld thickness equal to the thickness of the weld that is called out (S) minus 1/8". I should mention that I would prefer to not call out a particular welding procedure.
Is there another weld that I should specify? Do I need to increase the thickness of the cap plate or the hss wall?
RE: Cap plate welds
Fillet wont work?
RE: Cap plate welds
If the cap plate is slightly larger than the cross section of the HSS, use a fillet weld and mentioned by Toadjones. If welding in the proper positions with FCAW or GMAW processes, you can use BTC-P4-GF with allows S = E (no 1/8 loss).
www.FerrellEngineering.com
RE: Cap plate welds
If this is a nonstructural weld, indicate an all around fillet and in the note area, indicate a seal weld. As for the cap plate thickness, do you care if the plate is light guage (ie leave this up to the fabricator)?
RE: Cap plate welds
Just saying "cap plate" doesn't tell us much. In my nomenclature, a cap plate is an end plate on a column, and at least one beam bears on it. In that case, I would never use anything less than a 3/8 or 1/2" plate, with a 3/16 or 1/4" fillet weld all around and 4 bolts to the beam. If this cap plate is just for sealing off the top of a post, then most any competent welding arrangement will do.
