FATT test - X20CrMoV11-1
Hello.
I need to define a procedure to perform the FATT test for the material X20CrMoV11-1.
In theory this procedure will be based in the standards A370 and ASME Section III NC2300.
I know that we need to perform some tests up to different temperatures to define a curve. What I don't know is which range of temperatures should we test for this material.
Do you know any paper or brochure or whatever talking about this?
Thanks in advance for help!
RE: FATT test - X20CrMoV11-1
Is for that reason I am asking if anybody has experience with that.
Thanks.
Note that X20CrMoV11-1 is actualy a material for high temperature , so why would you be interested in its low temperature behavior. Secondly this material is not accepted for ASME Codes.
The problem is that I don't have any experience with FATT.
FATT is only used in low temperatures? Can we perform it at 100°C for example or more?
And then, which procedure/standard should I use instead the ASME code? Which EN talks about the procedure?
Sorry for these questions if they sound stupid, but I am a bit lost.
Thanks!
Fracture appearance transition temperature (FATT) is a reference temperature obtained from either Charpy or other impact test to describe the ductile to brittle fracture behavior of a material.
There is plently of reference material on the internet describing what is FATT.
