Contact types for heat transfer analysis by Ansys Ls Dyna
Hi all,
I want to simulate heat transfer from part A (20x10x2 (mm): for length, width and thickness) to part B (the same dimension with part A) by Ansys Ls-dyna . Which contact types I should use for this analysis. Thank you very much
RE: Contact types for heat transfer analysis by Ansys Ls Dyna
Here is an example : http://www.dynaexamples.com/thermal/welding
