Hole Table - hole text location and size
I am using NX7.5 for a hole table. I have set it so that I do not have a leader line going from the text to the hole. The problem is that the text is outside the hole by x+.5 y+.5 How do I set this to put the text in the center of the hole.
The second part of this question is how can I make the text in the hole a different size than the text in the chart?
[pipe]
RE: Hole Table - hole text location and size
just bringing this back up to the top. No takers?[ponder]
Drag it to the center of the hole?
Just edit text and scale the part of the text you want either up or down
Thanks for the reply Sam, currently I am dragging it to the hole but I am looking for a setting that will place it when it is generated so that we do not have to move it later.
