how to save only drafting sheet (without the Model) in prt format on NX 7.5
how to save only drafting sheet (without the Model) in prt format on NX 7.5,
is it possible by copying the drafting sheet and pasting on a new draft file or by copying the views and pasting on other drafting file
RE: how to save only drafting sheet (without the Model) in prt format on NX 7.5
If you used extracted edges you might be able to do something like this. But if all that it is that you're looking for is a 2D Drawing file with no model, you could try exporting a CGM file of your Drawing and then importing in back into a new empty part file or you could use the...
File -> Export -> 2D Exchange...
...to create a 2D version of whatever you have displayed in NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
and if you do it simply by exporting a CGM file make sure the text is set to "text" not "polylines"
