pressure rating
pressure rating
can somebody explain me what is difference between ANSI 150 and ANSI 300 pressure rating in gate valve????
RE: pressure rating
RE: pressure rating
RE: pressure rating
RE: pressure rating
David Simpson, PE
MuleShoe Engineering
"Belief" is the acceptance of an hypotheses in the absence of data.
"Prejudice" is having an opinion not supported by the preponderance of the data.
"Knowledge" is only found through the accumulation and analysis of data.
RE: pressure rating
RE: pressure rating
150-300-600-900-1500-2500(psi)
these numbers represent the pressure and temperature rating.one thing which should be kept in mind is that these are nominal pressure classes.
for example class 150# can bear more than 150 psi.
ASME B16.34 have the exact working pressure and temperature for each material.
regards
Arash
RE: pressure rating
David Simpson, PE
RE: pressure rating
I am not sure if your last post is related to me.if so I should say of course I have read the it.
is there any thing wrong here?
regards
Arash
RE: pressure rating
Hello 4094347496:
Your question asks generally for the 'difference' between ANSI150 and 300 classifications, and then seemingly you want to know the difference between flanges (and building lengt?, topwork? other?).
I presume, as often is for 'open' questions, that there is a specifc problem causing you to ask the question. Perhaps you want to know if a specific valve, for a specific process, can be substituted with one of the different class, or if you should select the one or the other class for a specific application, etc. etc.
If you want more precise and detailed advice it is always a good idea to give as many details as possible.
This is, after all, as zdas04 says, a forum with a large number of specialists.
