IPR output issue
IPR output issue
IPR output issue
Hi Guys,
I had a issue of ipr output.
when I tried to output tapping cycle on mill, I need set feed-rate = 1/pitch, change the feed-rate mode to IPR,
but after posting I can get right if feed_rate >= 0.1 (most time < 0.1 for inperial), when feed_rate <= 0.1 0.1 would be the only
answer, I even checked mom_cycle_feed_rate_mode = IPM (always this one), and choose mom_cycle_feed_rate_per_rev as feed, no luck.
I can not believe that UG post-processor does that.
thank you guys I really need fix this one.
davidtan20
