Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"Because of this forum, I continue to WOW! my clients!"
Geography
NTME76249 (Mechanical)
31 Jul 12 15:52
I am needing to buy a new computer for the house and was wanting to know what others have done for machines that will run SolidWorks at a limited capacity. It will be a home PC for the most part but I would like to do a little cad. All this for under $1000. That's the hard part.
Michael McMillan
http://cadtechie.blogspot.com/
AnnaWood (Mechanical)
31 Jul 12 15:54
Check out this thread on the SolidWorks forum.
https://forum.solidworks.com/thread/55131
Cheers,
Anna Wood
SW2011 SP5, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
KirbyWan (Aerospace)
1 Aug 12 9:31
For general 'how do I get the fastest computer for my $?' questions, I recommend checking out tom's hardware here:
http://www.tomshardware.com/
His focus is on computers for gaming, which I think is a good match for an all around home machine that will be used for CAD occasionaly. The one issue is using a gaming card vs. a solidworks approved card. I have an Nvidia GeForce gaming card and haven't had a problem, but since it's my home machine and I don't have to depend on it for CAD I'm cool with the occasional glitch. If this was a production machine and it was critical that it be rock solid then stick with the approved cards such as Nvidia Quaddro. More expensive, but also optimized for CAD.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
1 Aug 12 13:49
Thanks for the info on the GeForce Cards. I have always wondered how it did. Good bit of info.
Michael McMillan
EngineerErrant (Mechanical)
1 Aug 12 15:46
The Falcon Logical Increments PC Buying Guide.
As stated above, the only real difference between a CAD-oriented machine and a gaming PC is the graphics card; accuracy vs. speed, vertex calculation vs. shading, etc. A decently high-powered gaming card will breeze through most SW operations on all but the most complex assemblies.
"Engineers like to solve problems. If there are no problems handily available, they will create their own problems." -Scott Adams
MiketheEngineer (Structural)
3 Aug 12 15:45
Try Apple
mjcole (Mechanical)
7 Aug 12 18:11
Most of the ATI Fire Pro cards run solidworks exceptionally well and don't cost an arm and a leg. I've never had any issues with GeForce cards running SolidWorks well but don't expect to get tech support from anyone other than me cause If it's not on SolidWorks list of approved cards your Tech Support calls will typically end with an "It's not on the approved list so FU click" The only thing you won't get with a GeForce is a hole in your wallet and Real View graphics supposedly there are ways to trick your machine into thinking it has an approved card but I have not witnessed this. The GeForce I had wasn't one that had a driver from an approved card that could be used.
I use an ATI Fire-Pro 3750 on my home machine and it's a certified card with Real View capability. You could get actual Tech Support with one of those.
Michael
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
Close Box
Join Eng-Tips® Today!
Join Us             Close
