Excel Sheet - revision controlled by NX - Possible?
Any help on the following is greatly appreciated:
Is it possible for NX to revision control an Excel file as if it were a drawing and write the revision automatically to the header of the Excel file?
Thank you.
RLN.
Thank you.
RLN.
Solid Edge; I-Deas 7 to 12; NX4, NX5 & currently NX6.
RE: Excel Sheet - revision controlled by NX - Possible?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the response.
I need to be clearer on the requirement. I have an Item in NX with an Excel file as the only dataset. The item has one revision as revision A.
What I want to do is use the item>revise command and have NX / TC write the /B to the excel file like it does with a drawing.
Furthermore the part number written in the excel file needs to automatically be revised to B. Is that possible?
Thank you.
