10ft square x 40 deep shaft - how to construct
We are starting design on what is mostly a fairly straightforward light industrial building - steel frame, metal panel skin, etc.
One of the pieces of equipment that will go into this building requires a 10' square x 40' deep shaft. This is outside the range of anything we've previously done. We've been brainstorming ideas, but constructability seems to always come up short.
Any ideas or directions as to where to start would be appreciated.
Dan
Dan
RE: 10ft square x 40 deep shaft - how to construct
Actually, I'm not even sure that couldn't be done with a square section.
Richard A. Cornelius, P.E.
WWW.amlinereast.com
http://www.conteches.com/Products/Applications/Win...
That said, it looks like we are going to do just as PileBuckEngineer and Teguci suggest and concentrate only on the end result. Having to change our design later on due to unknown soil conditions will be relegated to additional services.
Thanks again.
