Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Thanks a lot Mate! I can't tell you how many times your site has saved my "rear". hehe..."
Geography
norkamus (Aerospace)
31 Jul 12 9:59
Hi all. I am trying to make a symmetrical part that is linked to the original. How I do it:
-copy the "body" in the part,
-create a new part file
-"paste special"- result with link.
-then I select the symmetry command.
at this point, CATIA suggests "Instead of directly transforming an import, we recommend you to apply the Add Position contextual modifier command to the solid. Then the required GSD transformation must be applied on the axis system of the positioning set."
Can someone tell me what this means? I could find nothing (as usual) using CATIA's help function.
Nick
Light structural commercial aircraft parts
PCDMIS 4.3 CAD++, CATIA V5 R20, NX6
APM Consortium Inc.
Cambridge Ontario, Canada
Helpful Member!  jackk (Mechanical)
1 Aug 12 23:43
Your method is best - I do the same thing, as long as both parts are exactly the same (just reversed)
Transformations, including Symmetry, are not preferred techniques in CATIA V5 because they can effect file size by duplicating the geometry. That's why you get that message. If you follow the steps in the message and you use a left-handed Axis System, you will get the symmetrical part but it will only slightly increase the file size. It's a lot of work, and hard for someone to understand when editing the part. It's better to use the Symmetry tranformation and ignore the message.
I have seen the Help description of Add Position in the past, and we had to use it before Axis-Axis Transformation was added.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
