High Pressure Reducer up to 500 bars antifreez
hi
i must feed a pannel with 10 bars gaz from 500 bars (reinjection gaz on well) +(containing hydrates) !!
attempts have failed because of problems of freezing and clogging in the pressure reducer.
is using reductive cascade can be a solution ?
many thanks
many thanks
RE: High Pressure Reducer up to 500 bars antifreez
see a similar thread
http://eng-tips.com/viewthread.cfm?qid=326725
adding heat or converting the process (for example generating some work in the process of expansion) may alleviate the problem.
