Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Since using forums in my early days 10 years ago in CompuServe, one had to log back on and sometimes wait days for a response. Now I get a response e-mailed to me which I can click a link and go right back to exactly where My post was..."
Geography
Aloumina (Mechanical)
31 Jul 12 4:06
We have installed AVK Telescopic Extension Spindles for buried water valves. How does the length of the extension spindle lock at a desired point??I can't find any installation guide.
europipe (Chemical)
31 Jul 12 4:40
31 Jul 12 5:11
Thank you for your response
The installation guide dosn't show how to fasten the length of the telescopic mechanism. Does it fasten??
If not how can we secure a joint with the stem of a Post Indicator ?
europipe (Chemical)
31 Jul 12 5:59
I dont think you can lock the telescope,
just push and pull.
maybe you can fix something on the outside of the telescope tubes
31 Jul 12 10:08
When installing telescopic extension spindles the cap should be over the ground level? I can't see any other way to mount a Post Indicator on them only if their length is enough so the cap is over ground level .If the length isn't enough and ta cap of the telescopic extension spindle is underground the mounting will be impossible.
Am I wrong?
europipe (Chemical)
31 Jul 12 11:43
You don't need an indicator for a gatevalve, so I think You have a ballvalve,
Can't You just note it on the handle then? or with a sign?
31 Jul 12 11:56
Nope it must be FM approved.. FM obliges us to use indicators
Anyway I will call a supplier tomorrow. Thank you for time
Is it right to refer to the housing of the indicators as Post Indicator or Indicator Post? I have seen it both ways
europipe (Chemical)
31 Jul 12 12:13
I'd say post indicator
Close Box
Join Eng-Tips® Today!
Join Us             Close
